Low fuel pressure (2000 5.3L)
According to my fuel pressure gauge (autometer), I am currently sitting at 30ish-psi and at running/WOT it jumps to 40psi. I changed the plugs, wires, regulator and fuel filter but I am getting the same readings. My experience with these fuel pumps is they are either good or bad. I haven't had one getting weak, they just die. I keep having a misfire on cylinder 6, that clears up some when driving. Injector balance test shows the same across the board at 38psi (again, on the autometer gauge). Where would you look next?
Plenty of pumps get weak. Pressure spec is 55-62 at key on, engine off. Your running pressures are too low. I'll suggest time for a new pump. You could always check voltage at pump to make sure you have no bad connectors or wiring. Check ground also
Put in a Walbro 450 and something else is on the fritz. I turn the key on now, fuel pressure goes to 38pis, then bleeds off.
sounds like you should have used a delco pump.  that one sounds bad
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 579 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
