I’m coming from a 2012 to a 2018. In the 12, when it rained, i didn’t get any additional noise in the cab from the road spray from the tires, but in my new truck, it’s really quite loud. Several people who have ridden with me during a thunderstorm have asked what the noise is. I’m pretty positive it’s just the wheels throwing water up into the wheel well, but I’m wondering if it’s normal? I do have the factory carpeted wheel well liners, which my 2012 didn’t have, but I would think that would make it quieter, not louder. Anyone else experiencing this? I just want to make sure nothing is wrong
My liners deaden the sound from the road pretty well. I have noticed a little low frequency “ringing” from spray hitting them when driving through water.  I think it would be louder without them.  As far as I am concerned the liners are a great addition.
Edited by Darksky
  • 1 year later...
Did you find a solution? I find it very annoying....
Nope, just got used to it. Out of that truck now and in a Trail Boss. The new truck doesn’t do it
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 757 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
