Fixing leaf spring popping
How are most of you fixing the leaf spring clunking noise on these trucks? Anyone have luck getting dealer to replace?
Here’s the google search of the threads on this site for leaf spring noise.
https://www.google.com/search?q=2015+silverado+leaf+spring+noise+site:www.gm-trucks.com&source=lmns&bih=1010&biw=834&prmd=svin&hl=en-US&ved=2ahUKEwjI36TLgezgAhXJjIMKHScYCNIQ_AUoAHoECAAQAw
as you can see there’s many many threads on this subject.
To answer your direct question. YES some have got the stealer to replace them others NO. Most of them that have been replaced it was warranty work mostly bumper to bumper.
Fixes
1. Power wash in between all leafs
2. Power wash/scrub between all leafs and use your choice of lubricant everything from wd40, PB blaster, axle grease, silicone spray, and ect. I forget them all...
3. Clean leafs jack up rear so suspension hangs free and place your choice of rubber from a bicycle inner tube all the way to thick rubber sheets bought from home store in between the leafs lower truck off jack before driving.
4. Same as #3 only using other miscellaneous materials in place of rubber.
5. Leaf spring clamps. Probably after a good cleaning? I forget
6. Replace one or both assemblies with the “updated number” springs at your cost, dealers cost, GMs cost, 3rd party warranty or some combo of the above.
6A. Go to local driveline/spring shop have custom springs made and installed
6B. Purchase a MONSTER lift 6+ inches that comes with new springs install or have installed at local 4x shop
7. Drive truck to competitors stealership of your choice and trade for that brand truck telling yourself it’s the best damn thing ever leaving your comparison of said truck to old truck on this forum and how we should all do the same before disappearing off this site and joining saidtruck.com forum to complain about all the features your new ride doesn’t have and how sh!tty it rides compared to your old truck.  It’s a vicious cycle...
8. Read 25 threads over the course of 2 weeks about “how to fix” , get discouraged, give up, crank the tunes and decide to live with it.
Everyone of these “fixes” except the last one or two. Some people will say fixed it forever, some say worked for X amount of time, some say came back, some say didn’t work at all.
I choose number 8 for a couple reasons first I don’t recall ever reading where anybody had any kind of ill effect from them making noise other than noise, I ain’t paying for new factory springs to maybe or maybe not have it come back, and mostly I live on gravel so keeping them clean and lubed ain’t happening in this lifetime.
I might someday if I run out of other sh!t to do to it try some rubber but since it hasn’t happened yet it probably ain’t going to happen...
Best of luck in your decision & choice!
Oh I forgot another “fix” is retorting the ubolts anywhere from factory  torque specs to as tight as you can. Again some say it’s forever fixed to it didn’t do anything.
Yes I got both replaced under warranty also my rack n pinion since I have a 2” level was make noise when turning
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,047 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
