OEM HID issue
Hey guys, ive searched the forum and found a bunch of threads with similar problems, but for guys trying to convert to HID systems from halogens . I have a 2015 2500 hd all terrain with factory HIDS. When the truck is off, the headlights work fine. Turn the truck on, and after about 30 seconds, the lights blink a few times and turn off and will not turn back on until i turn the key off and reset. i know on other threads where guys have halogens and install hid kits, the solution is the capacitor or anti flicker hardware. This truck came from the factory with HIDS, and has the stock bulbs/ballasts and im getting this problem. i have no errors on the display cluster. When i also try to turn off auto headlights, i do not get the auto light disabled message.  Any info is greatly appriciated.
The issue on all HID systems is current. They pull a ton for a second then not much but the ac output to the bulb causes the pulse. Anyways the fix is, assuming ballast are good is track down the resistance into the feed wires or as I have done so many times it is automatic no brainer is a relay. They sell pre wired harness that are pnp. It will take the power and ground from the factory plug and power a relay. The relay needs super low power to click on then. The common wire on relay goes to the battery. This will isolate the wiring and allow for 30/40amp draw. All my old cars and trucks had aftermarket HID kits and relay harness. Even the fogs. Then I can add jumpers with diodes to add high,low,fog all at same time if high in car is pushed. Sounds hars but really super easy.
this is what i have now. from doing more researxh, i believe i have determined that my 2015 2500hd all terrain did not come with hids from the factory. the previous owner must have added these OEM hids and did not do it the right way.
Mine didn’t come with hid so I upgraded to the hid and was having issues with the flickering and the relay harness hum so heres what I did to get rid of the issue
    • Just buy the tube and move on with life.
    • Glad that worked, and in this case that is all on Autel for somehow dropping the ball for not updating the GMC section properly.    I believe in the basic section or unless it is in the advanced, when one does a check of lets say individual sensors for what the pressure is ( and it shows a temperature as well ) , I think it picks up on what the model number of the sensor is in a certain section where you choose "OE" sensor or at least mine is telling me what the model number is and matches to what they actually are and that is the number I quoted in a prior post.    I don't recall now if I had said prior that I discovered with my truck anyway that no matter how low I set the placard pressure for the rear tires, if the physical pressure is under 35 psi and I drive it for about 15 miles the pressure warning will come on for one or both rear tires. I am speculating that there is something else in the trucks system that over rides the placard pressure setting once it drops below that minimum pressure to run a metric LT tire at. The weird thing is it does not trigger right away after driving a shorter distance, it took that longer drive for it to trigger. Just something to keep in mind if you were experimenting with pressures below 35 pounds for a tire designed for lower pressures ( larger than stock floatation series tires ) and not being overloaded of course.
    • I've seen a scant few YT vids on them, but it's always in a performance application.
    • No clue. Service advisor said he'd call me this morning, which I'm 99% sure won't happen. They had the truck 5 days, and I didn't hear a peep. Finally had to call them yesterday. I guess they'd be content to just let the truck sit in perpetuity.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
