Hi does anyone out there have random issues with there 2016 Silverado not starting. I sometimes turn the key and only get 0ne click and I can use a boost and it starts immediately or I can wait awhile and  it will start with no problem
Load test battery. Then check cables and ground. There is some post about it but hard to say it is your same issue.
Negative battery cables are supposedly bad. Causing numerous issues. I need to check mine.
I have heard of this. But I'm sceptical on the remedy. I have a extra ground to block.
Also check your starter. Mine went bad with less than 35k on odometer. One day it would start another day nothing. It was burned up where hot wire was attached and making poor contact.
Sent from my VS995 using Tapatalk
