So this is the second time this has happened since I bought the truck last October, jump in my truck (2017 Silverado 2500 HD 6.6 diesel) and less then a mile down the road and everything starts shutting off (stabilitrak, ABS, trailer brake system, park assist) and warning lights coming on! Then a mile down the road they all turn off for another mile and them come back on and stay on. However the next morning I get in my truck to bring it to the dealer and everything is fine, but I dropped it off anyways, but I am sure their going to say that they couldn't duplicate the problem and give it back to me.! Does anyone have any suggestions?
Intermittent ground someplace in the system.  Its a nightmare to trouble shoot and requires system diagnosis experience rather than the usual "did it throw a code" swap parts techs.
That's what I was thinking, but was hoping wasn't the answer! Thanks for the info
9 hours ago, bimmerboy318 said:
Any resolution from the dealer?
No help from the dealer, sense they "couldn't replicate the problem". So, next time if or when it happens I heading straight to the dealer so they can see it and plug it in.
  • 5 months later...
Mine is doing almost the same thing. The gas gauge goes to empty, the batt. light comes on, the airbag light comes on and the abs along with the brake light. It doesn't always happen just every now and again. I've had the cluster completely rebuilt along with the computer went through and still having the same issues.
  • 2 years later...
I have a 2016 GMC for the last year on occasion my stereo doesn't work properly until I shut the truck off for a minute or two. Now today on start up I received every dash warning that I believe there is The gas gauge goes to empty, the batt. light comes on, the airbag light comes on and the abs along with the brake light the speedo doesn't work the tach didn't work the odometer didn't work. I stopped to put fuel in and when I started again everything seems to be normal. My mechanic said either a ground of ignition switch because it is on start up I am thinking ignition?????
  • 9 months later...
Has anyone figured out this issue? Mine has done this off and on for the last couple of years, but only when it was really hot outside at first. Now it's just random a more frequent. I do have subwoofers hooked up, but they were done in a shop, and should be properly wired. Can anyone give me some connections to look at and how to tell?
Good luck. I’ve been having same issue since I purchased brand new 2017 Silverado and the dealer couldn’t find problem and keep taking it back and now they say it’s out of warranty and want to charge me a fee.  Piece of ******   Now as of today they are putting the SECOND transmission in it with only 37000 miles on it
We are sorry to see you are having concerns with your Silverado and would like to investigate further for you. Please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to your email.
    Afennell19
    Afennell19
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
