Greased Lightening fuel additive
Well just to let everyone know, I tried the greased lightening fuel system cleaner. I used it because my truck has that ping type noise on acceleration and hi octane fuel does not do anything for it also the dealer says every code is normal. I was really hoping this stuff would clear it out. It costs about $9.00 a bottle and they claim it is only needed once every 15k miles, plus it came with the money back guarantee. The only improvement I noticed is better throttle response, not huge but noticeable. They claimed some people got better mpg, but after 3 tanks of 91 octane, I still only get 14-15 around town, with the 4.8l. I want to get rid of that ping, but the dealer is passing it off as piston slap that they already gave me the extended warranty for. I like this truck but the ping sucks! Anyone been able to get the pinging noise diagnosed? I would like to try another dealer, maybe someone else could get a handle on it. :thumbs:
have you tried different brands of gas? I've consistantly gotten better mileage and power from texaco gas than bp and especially citgo. I've also noted I get better mileage from 87 than 91. I'd think the dealer would be able to tell the difference between csk and pre-detonation, but if your sure it is pinging, try another dealer. I don't know how well greased lightning works but have heard a lot of people say good about the amsoil PI fuel treatment and the techron additive.
I always use Getty fuel, but out of desperation I tried Sunoco 94 or 95 octane and still got the ping. One thing I notice on this board is that everyone seems to think piston slap and csk are the same thing. They are not, my truck is quiet as a mouse on cold starts, my wife even calls it the "stealth truck" because it is so quiet. When I accelerate it makes noise, the harder I accelerate the more pronounced the noise is. The dealer and GM both told me this is piston slap, the piston slapping against the cylinder wall because the skirt is so short. Maybe it is, but it sure sounds like pinging to me. It was strange cause it never happened until I clocked 20k on the truck.
CSK or piston slap is the same thing, generally most engine that suffer CKS or piston slap only do it for the 1st minute or two then stop. Pinging due to timing usually is under hard acelleration or slow acelleration with a warm engine. CSK sounds sound just like a HARD KNOCKING sound and pinging sounds likea tinny hollow sound. Hope this helps, I have CSK and I have never heard my 8.1 every knock under any circumstance, even with the WESTERS advance timing. :eek:
I guess try taking it to another dealer. Sounds like a bunch of carbon build up and running a higher octane can do that. I'm not a pro at it but that is my best guess/opinion.
The AMSOIL PI and Cheveron techron is really good stuff and I have heard others say good things about both.
Also as a fuel conditioner /cleaner is the Fuel Power that I purchased. I read about it on bobistheoilguy.com they talked about it and had great results. I noticed that it gave me about 1 to 2 more mpg it seemed. It comes in a gallon and you only use 1 oz per 5 gallons of gas. So that one gallon treats 640 gallons of gas. So economically it is a good price. I paid $35 for the gallon and that included shipping. It might help with your problem or it might not. Just a thought.
I only run the 87 in the truck. No pinging or other problems. I keep my fingers crossed and count my blessings on that. I have 38k on it now.
Does anyone you know have access to a Tech2 or Sensor reader? It would be interesting to know what your timing numbers are. Knock retard?
Twice I have bought it into the dealer and both times they claimed the timing was right on. They replaced both knock sensors and cleaned the top end for carbon, that is when they gave up and said it is piston slap. They showed me the now famous service bulletin saying cold start knock is piston slap which is normal. I said : why is my engine quiet, on start up, no noise whatsoever, even in the dead of winter after sitting in 0 degree weather overnight, yet it makes noise under load?. I can leave it in park and rev the hell out of it and no noise. Drive it down the road at 30 mph and it pings! They replied: they are all different, some make noise on cold start, some don't, some make noise under load, some dont. I guess I will go to a new dealer as soon as I can get a day off from work. I just dont believe it is piston slap, but who knows???? Thanks for the comments/advise!
  • 4 weeks later...
I'm still confused as to what pingin sounds like...not sure if I have it. Will it make the SES come on? I get it confused with the tappping sound or CSK which I do have, but we all know the story with that. If I go under the hood and manually accelerate the TB what should I listen for. I don't exactly know what I'm listening for and help would be appreciated. The alternator and FIPK so close its hard to tell.
Does it sound like a flutterrin sound... :jester:
It is real hard to describe the noise. One guy on this board described it as "marbles being shaken in a jar". I can only tell you that the ping from my engine is only on acceleration, never while in park or neutral, and the harder I drive it the more it pings. I plan to take it to a new dealer for a second opinion, I just dont buy the piston slap story.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
