My GMs
ToeJam
Here they are in Montana. Buddy and I left Seattle at 4:30am Saturday morning and got into Great Falls around 3:00pm. Turned around the next morning and headed back to Seattle.
Travel facts = 1,250 miles, 22 hrs travel time, 10.3 average mpg, only one near elk miss and XM RULES!
Thanks MCourson...
Oh yea, the pic is yellow because of all the smoke... half of Montana is on fire right now (at least is seems that way). There was smoke in the air across much of the state.
The truck pulled it pretty well up the passes, we were able to maintain about 50mph up the big hills. I think there were three, with the highest one at over 5,000 ft. My folks '87 Tahoe had better logic in the transmission, which kinda pissed me off. The Denali would skip 3rd and jump straight to second gear when downshifting....but that could have been part of the loads fault too. I think we were pulling pretty close to 6,000 lbs with truck, trailer and gear (took every tool I had because I wasn't sure of the C10's condition.)
Very nice. :confused:
Are you the one that got it from a relative (grand father-in law, or something like that) for very cheap, or am I thinking of someone else?
Yep, that be me. The $1 I paid them was handed back to me on the way out...
The C10 is in great shape, especially for spending its entire live in Montana where they salt the roads. Everything seems to work just fine, but the engine could use a tune. Its got the 250 I6 motor, four speed manual and 88,000 miles. There is a little rust one some of the panels and one dent, but that is about it. Even the wood bed is in great shape, just needs a new varnish.
I6 :eek::puke:
Dad's 61 has the 235 I6 and a 3 speed manual. Too bad it doesn't look anywhere near that good.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
