Heater, Vents, A/C Control Panel
1990 GMC C1500 Sierra, TBI 5.7 L.  Passenger side header (Pacesetter Shorty) gasket has been leaking for months. Crappy fiber gasket just failing apart.  Decided to replace gasket with AC Delco multi layered metal #12550033.  OK.  First thing I do is disconnect ground cable on battery.  Then start to work.  Remove the K&N air intake.  Removed bolts and spark plug wire brackets.  Disconnect the #4 and #2 spark plug wires to get better access.  Header bolts OK and easily removed since headers were installed in frame-off restoration in 2016.  Old gasket just shattered in about 30 pieces.  Header can be eased away from block but to make it easier, I decide to remove the 3 old and  rusted bolts holding header to Walker Y pipe, and replace with new grade 8 bolts and brass nuts and lock washers (that was 2-days of fun).
Get everything back together OK.  Go out for road test and I notice the heater, vent, air display is crazy light up and nothing works.  See attached photo.  No fan.  Vents not opening.  No air.  No heat control.  Wondering if I inadvertently jiggled or disconnected some wires in the engine compartment.  Checked for anything obvious.  Jiggled wires at connectors.  Popped a few connectors.  Checked the under panel heater fuse (OK).  NADA, NOTHING.  Pulling the fuse shuts down the display.
When I reconnected the battery, did I fry something ?  Anybody see anything like this?  Any ideas on a fix ?  Or am I heading to an auto electronics repair shop.  I'll be searching forums for anything similar, but most of these responses have to do with a loose connection at the panel... either light up or not light up
Disconnect battery again, then re-connect. Turn key to on, but don't start. After a minute or two see what happens. Just leave the controls alone during this period
Thanks for the response guys.  Before seeing your posts this morning, I tried a couple of things yesterday, and apparently the problem has been resolved.
I decided to pull the heat control panel unit out of the dash to check it out.  Disconnected the battery.  Pulled heater fuse out of its slot.  Removed the dash trim bezel (unplugged wires), then unbolted the heat control.  Pulled it out as far as I could, and realized I needed to remove radio to access the wire clips.  OK, but didn't have time to continue.  Put everything back together, installed heater fuse, reconnected battery, and guess what?  Everything started working again!  Even the radio controls, which I've had intermittent power on/off issues, was working just fine.
Doing some YouTube research last night, several videos mentioned how the main dash wiring harness rests on top of the heater, A/C control connection causing intermittent problems and a poor connection.  Other videos speak to the poor design of connectors, harnesses, and poor grounding wires, and are a source of a variety of dash panel issues with this series of GM trucks.  My pulling the control unit out probably repositioned the wiring harnesses.
One response to my post described a control unit reset by disconnecting battery, re-connect, turn key on but don't start, wait a minute or 2, then start up (thanks TXAB).
Hopefully the harness jiggling fixed the problem.  I'll monitor the issue.  I intend to pull the radio at some point.  Another problem I have is the defroster vent is not opening completely.  I need to remove the radio to access the vent actuators which have a tendency to stick (another YouTube fix).  Plus, on this truck, I have a working factory tape cassette player in the center of the dash.  I'm thinking of removing radio and cassette and replace it with a single or double DIN radio/CD, but defroster vent is the next issue to address.
Oh, and I also need to replace the header gasket on the other side as well.  Don't we just love working on these old trucks.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
