sensor relocation for grille guard
do the parking sensors have to be relocated for all types of grille guards?
Good question. I would think you could just unplug the centre two sensors but I am not sure if they are wired in a series and require all sensors to be operating and communicating with one another for the park assist to function correctly, I have never had mine disconnected or even looked at them really. I would suggest unplugging the 2 centre sensors and see if the system is still operational before buying and installing a bull-bar. Worst case you will have to drill and install them in the bull bar.
