Hi guys I'm new to the site.
I have been doing some searching to try and diagnose my problem.  I have a 2017 Silverado 1500 and I keep getting a 2635 code.  It's out of warranty so I am trying to figure it out without taking it to the dealer.  It was at the dealer a few weeks ago for this problem and they replaced the fuel tank pressure sensor and the EVAP purge valve.  I also ordered a fuel line pressure sensor and will be replacing that in a few days.  I can clear the code and it will come back a few days later.  I also noticed to day that my volts gauge dropped to around 12v when I was driving and the cel came on shortly after.  Somehow my voltage drop is affecting my fuel pump performance.  The voltage drop is completely random from rpm/speed/or what electronics are on.  Sometimes it will be just over 14 and other times it drops to around 12.  It doesn't jump around and it usually stays at that reading for a while.  Anybody have any ideas?  Alternator?  short circuit?   Thanks
Ok thanks I will look into that.
Are the schematics posted on this site anywhere?  Looking for the location of that ground.  I'm assuming it is close to the tank/spare tire and grounded to the frame.
Well that didn't fix the problem.  I replaced the fuel line pressure sensor and also cleaned the ground located under the drivers door.  I also checked the two grounds located in the front corners of the dash and they looked fine.  For some reason when my alternator switches to the lower amp setting around 12.6V and I give it moderate acceleration I get a cel with p2635 code.  Anyone have any other ideas?
  • 5 months later...
I am also curious what you figured out, I just bought a 2017 and mine is doing the same thing with the battery voltage and throwing the same code. The fuel pump at the tank also has that scream that the late '90's Chevy's had before they went out.
  • 5 months later...
I am also curious if you ever found a solution.
I am having this identical issue with a 2017 GMC 2500 with the 6.0...everything you said I am having the same issue with...Does anyone think changing the battery could be a fix?
Edited by MaverickB
Hi all, I'm having the same issue with the code P2635 on my 2017 GMC 1500 4wd in including the voltage drop. Has any body find the solution to the problem?
  • 8 months later...
SAME 2017 Siverado. Replaced battery awhile back. Now P2635. The more I look into it the more I hate Chey. Some people are saying it's a problem with the programming of the computer
Sprayed computer above spare tire with carb cleaner haven't had the code come back been a couple days. I did replace battery at 30,000miles. 2017 silverado. Fingers crossed 🤞
  • 10 months later...
    Mistycool
    Mistycool
  • Who's Online   5 Members, 0 Anonymous, 1,671 Guests (See full list)
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
