possible wrong wheel hubs?
2008 LTZ front left wheel hub was making noise so I decided to replace it. Got the old one out, new one in, and realized the connector is not the same as the factory one. Aggravated I clipped the connector off the old one and new one and soldered the old connector on the new hub. Took the truck for a spin and a block down the road the abs light, stabilitrac off light, traction control light, and tpms lights all came on.....so even though it bolts up, with a different connector I'm guessing the hub is just completely wrong and need to replace the whole thing again or is there a process I missed?
Yes wrong hub assembly, happened to  about 9 months ago when I returned it the correct one was $35.00 more. Different plug and sensor.
And since I clipped the connectors I can't return it. Luckily it was a cheapo from rock auto. Guessing it's good to drive on until I order the correct one?
4 hours ago, swathdiver said:
Timken SP500301
Just found that one. I'm ordering it now. Thank you
