well, I had a new, but small issue today.  Started the truck, put it in drive and the screen lit up green with the reverse lines on it,  it stayed that way for about 15 seconds, then went back to normal, has anyone else seen this?
What truck? HD or standard rear vision? There a few threads on rear vision. Problems are with the smaller screens.
Edited by mafd2
I believe its the hd,  its a sierra slt.   I have read some of the other issues, but haven't seen anything like this
  • 4 years later...
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
