Truck Bed Adjustment
pwgsx
How would one go about adjusting the truck bed on a 2017 Silverado?  I bought this truck new and never noticed, not sure if this just happened or if it had always been like this.  The passenger side near the cab is sticking out 1/4 -1/2 inch, enough where I can see it in my side mirror.  Hoping this will be easy to correct.........
It can be done by the dealers body shop, this a common problem, sometimes being the cab or bed are not aligned correctly.
If you really want to be happy about your truck, look down the body line at how your doors fit, check the spacing on your rear bumper, and then do the same on the front bumper.
All can be fixed, some easier than others.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,150 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
