Was just going through checking what Amazon had for their Amazon prime deal days...found this Torq Torqx kit.  I figured this would be a good entry level kit for those wishing to do their own buffing/polishing.  Comes with the RO polisher, pads, backing plate, and chemical guys polish and compound kit.  Polisher alone is listed at $117 while the entire kit is $112
TORQ TORQX Random Orbital Polisher Kit (9 Items)
And, it's now back to $160
  • 3 weeks later...
Had it    it's good for small stuff but that's about it.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 255 Guests (See full list)
