Separating Stop- and Turnsignal
Hi,
so in order to use my trailer hitch, I need a Euro-Trailer Connector (13-Pin). So that means I need to separate Turn Signal (Left/Right) and the Stop Signal. Otherwise, the Turnsignal (Yellow) and the Brakelight (Red) would light up together on the trailer.
The first solution I came up with is taking two relais (To not mess up with the Can-Bus/Lightning System) and take the Signal from the Front Turn Signal Lights and bring the cables back. And another relais for the stop signal, and bring this cable back also.
Anyone know a more "elegant" way to do this? There is this connection box in the end of the truck where the taillights and all this stuff are plugged in, can I get a separate Signal there? Or do I have to take them from the BCM in the front?
EDIT: Ok, so I found that the junction Box under the Bed provides a separate Stop Signal. So I just need the separate Turnsignals.
Thanks! This would make everything a lot easier. I just sent them a message to see if this will work the way it`s needed for making my truck road legal.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 307 Guests (See full list)
