HVAC issue
Can anyone help? My ac/heat quit on my 95 Tahoe. No blower, no acuator movment for hot/cold, and the doors are all locked for air flow to the floor and dash vents. When you move the fan speed selector the ac compressor does kick on. I checked the blower motor and its fine. I replaced the fan switch and everything worked for one day, but quit again the next day :thumbs: . What could be wrong besides the entire controler?
Mine just did that.. i had to buy the ac control panel.. I actually have another one here.. ill get it to you 100 dollars shipped...
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
