Need some more info. Couple questions:
Which transmission, 4l60e or 4l80e?
Was this condition present before replacing all the items you listed?
Are any of the parts new/used/reman?
Is it not shifting out of 1st gear at all? Or is it shifting from 1st to third (after revving high) and then to 4th?
Is the check engine light on? Any codes, and if so which ones?
When did this condition start?
If you don’t have second gear at all but everything else is okay I suspect a solenoid or other electrical issue regarding the transmission. When you manually put it in 2nd what happens?
