For Anyone wanting to run RCX 3.5
So this thread is probably moot as I do not own my 2011 Silverado anymore but I feel I could give a little insight of the issues I had with my RCX 3.5" lift, I purchased the kit with the UCA for Christmas and did the install myself (very proficient with suspension installs as a DIY person). After the install I took the truck to 4WP to have an alignment where they told me that it would not be perfect as the angles were no where that they should be (meaning the TRE and LCA and BJ) the UCA BJ was at a decent angle (as it is supposed to be with the kit) and after the alignment they had it as good as they could get it (I have the paperwork somewhere I think). But I just want to enlighten some of you newer guys who want to put this kit or others like it on your truck to some issues I had. 4WP told me that the tallest leveling kit I should run "shall not be over 2.25" or it will begin to severely wear the suspension components", me being young I didn't care. I put approximately 30,000 miles on this kit before I had issues, some mild and a few times with hard offroading (2-4 times I cant remember). The ball joints popped out of the UCAs and the LCA BJ were shot, as well as the TRE. I ended up replacing the whole kit with the Procomp prorunner shocks that gave the 2" level and had zero issues (ride quality was shit for me as I had 33" mud graps on it and Chinese mud grips )
I've had friends go with this setup on 35" graps and have 0 issues, but those were street driven.
I don't want to turn anyone away if they have heard better or feel it would be okay for their setup. I just want to enlighten my issues with RCX 3.5" lift w/ UCA. Installation has you drop the diff which is a plus and you have to cut the crossmember for the rear of the LCA bracket, but overall wasn't horrible.
If you have question I can answer to best of my ability, my 2011 Silverado 1500 Z71 4x4 was running a procomp prorunner 2" shock level with 33" mud grapplers and had the wheel well liners ziptied back and I am pretty sure NORCAL mod done to fit them.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
