royalkangaroo Posted July 27, 2019 Posted July 27, 2019 I’ve got a set of P-rated Duratrac tires now with ~25k miles on them. About 5k miles ago, I noticed some feathering/cupping wear on the inside edge of the front tires. I had the dealership inspect it, and they were able to adjust the toe to within spec. (One specifically was out more than the other). Fast forward to now, 5k miles later, and I’m noticing feathering/cupping on the outside of the front tires. Tires in the back seem to wear flat. I rotate them every 5k. What is going on?
HoosierZ Posted July 27, 2019 Posted July 27, 2019 If tires are toed out they’ll wear the inside edge. Toed in will wear the outside edge.
newdude Posted July 27, 2019 Posted July 27, 2019 The original cupping/wearing on the inside sounds like more negative camber than what the spec should be. Now it sounds like a toe issue.
royalkangaroo Posted July 27, 2019 Author Posted July 27, 2019 The alignment was done less than three months ago, you’d think it wouldn’t be out of spec already?
grandpalarry777 Posted July 28, 2019 Posted July 28, 2019 Cupping is frequently caused by weak shocks/struts. I had a car that had chronic cupping problems. Had it aligned, tires rotated, etc. None of those things helped. New shocks all around and new tires solved the problem. You might want to check the shocks as part of your investigation. Good luck.
royalkangaroo Posted August 6, 2019 Author Posted August 6, 2019 Dealership claimed no suspension issues between shocks and ball joints. Told me that’s the nature of an aggressive tire, uneven wear. I’m going to get a second opinion.
MaverickZ71 Posted August 7, 2019 Posted August 7, 2019 21 hours ago, royalkangaroo said: Dealership claimed no suspension issues between shocks and ball joints. Told me that’s the nature of an aggressive tire, uneven wear. I’m going to get a second opinion. Dealer is full of crap and too lazy to diagnose and find the problem. GM wouldn't install Duratracs as factory original tires if they had a built-in wear problem. Uneven wear is caused by an alignment or suspension problem, not the tread design. Doesn't make any difference if the tire is a racing slick, a highway tire on a car, or an off-road all terrain truck tire.
