1999 Suburban 5.7 crank no start
I have a 99 GMC suburban, 5.7L 4wd, it's not getting fuel. the pump works, sender is good, FP relay is good, and all the wiring in between. The problem is the ECM / PCM / VCM is not energizing the FP relay. I checked this at the module, and there is no control signal to the relay at key-on. However, if I jump the pump and start the engine the pump runs fine. Kinda Sounds like a bad ECM, but I'd like to know, is there any other input (or lack of one) to the ECM that will cause it to not energize the relay?
Meaning what exactly? the green/white wire that goes from PCM to FP relay and energizes the relay switch is in PCM connector C4 I believe (which ever one is labeled "black"). All the terminals in that connector are nice and clean. In fact, almost all the terminals are surprisingly clean, except the fuse terminals which are all kinda brownish. Not damaged, just brown.
Meaning that, exactly,lol,darn,this is rare,right,it runs fine when jumped,for just one circuit to go down,do you think it's worth putting on a scanner,and commanding the pump on?
So I forgot to mention the problem is intermittent. Well, more like it intermittently doesn't have the problem XD
Anyways, during no-start the gauge is pegged out way past full. For a while, you could let it sit for several minutes and all the sudden the gauge would come alive and read right, and then you could start it. After the gauge comes alive, if you turn the key off and wait for 5 seconds before turning it back on, the problem comes back. If you turn the key back on within 5 seconds there's no issue. Today I cut out the crappily installed butt-splices in the 4 wires at the fuel pump/sender and installed new ones properly. The problem is less now, in that it usually only takes a few seconds instead of minutes before the gauge comes to life. I was able to scan it and it had a code for high voltage on fuel level circuit. Cleared it and it hasn't come back, so im assuming its from my buddy connecting random wires up trying to fix it. The fact that putting in good connections made the problem so much better makes me wonder if I should just re-wire the fuel level sender.
    Markey
    Markey
  • Who's Online   2 Members, 0 Anonymous, 2,472 Guests (See full list)
