Trailer camera display in rear view mirror
I have a 2015 Silverado 2500hd LT.  I added a backup camera. I tow a 32 foot travel trailer with a Furrion observation camera.  I was wondering if I could retrofit an older rearview mirror with the display in it and couple the Furrion to that mirror.  Instead of having a separate monitor for the Furrion camera.  Any help would be appreciated.  Has anyone done anything like this?
Daryl
  • 7 months later...
  • 4 weeks later...
I would think it would be easier to go with an aftermarket mirror and wire in that way with an RCA than trying to go the OEM route.
