Speaking of these new tailgates. There is no more manual opening latch. How would one open said gate if the vehicle battery is dead, especially with a tonneau installed?
  • 6 months later...
I installed the light bar this weekend but it seems like my tailgate drops a lot faster and almost slams lightly when it opens. I'm not sure what happened.
Any suggestions for getting the passenger side back on on a 2020 GMC 2500 At4 with the multipro (if that matters)?
I was lifting the tailgate up and pulled it off the passenger side. Can't seem to get the angle anywhere that looks like it might work.
Thanks!
Thanks!
Nevermind. Rotated piece on truck.
  • 2 years later...
I have a 2nd connector from tailgate harness, anyone know how to disconnect this one 😛
Slide the red tab down and then press on  the white tab beneath it and pull apart.
    tararebecca
    tararebecca
  • Who's Online   1 Member, 0 Anonymous, 586 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
