2007 Chevy 1500 6.0 gas
07 Chevy 1500 with gas6.0. Started up and put in reverse. Truck died. Now I have no crank, no power to door locks windows dome lights lailights or turn signals. Tried new starter and new battery. Any thoughts.
Thanks
My '08 did this several times and I never figured it out. Last time, I unlatched and removed the underhood fuse box, checked all pins, and reinstalled which gave me power. I never determined what was loose or causing the issue, but this worked for several months. Previously I had built a new main ground cable and power cable with larger gauge wires, but that didn't help. I finally just had to get rid of it because it left me stranded too many times. I hope you can find the issue!
By putting it in reverse,says the motor rocked in it's mounts, stressing wire(s),put high beams on,and start wiggling power and ground feeds off of battery,and watch headlights for a blink,or dimness or brightness
So you checked and re-checked and cleaned all your grounds and cables to the battery?  How about that junction on the firewall near the battery?  If all that is good, it's likely in the key ignition.  Is this an NBS Classic GMT800 or GMT900 NNBS?
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
