Rear Bumper
MEIN TEIL
I dented my rear bumper on my truck. And I really would like to pit a 2014 bumper on a 2010 Chevrolet Silverado.  Will it fit or they inter changeable
yes it fits, even the mounting bolts are in the same location, you will have to cut out the lower corners of the box to allow clearance for the step pocket. i put one on a 2007
