I get a wind noise on the drivers door. Seems like it is around the windshield post and where the door meets. It almost seems like it turns into something rattling.It does not do it all the time.yesterday I drove 60 miles and no noise. Today it's making the noise. I checked the mirror and door seals and been trying to figure it out for a week.this one has me puzzled. Maybe it is inside the door.Today I made an appointment to take it in.not very confident with shop as yesterday they said they could not hear my axle jingling away as we drove down the road.
I have a 2019 Silverado LTZ with the same problem. Fortunately the service techs heard it too. However, without an existing bulletin on the specific problem, they are going to have to take the door panel off. It's like having a family member undergoing major surgery.  I'll post the resolution if they find it.
Thank you. I drove 180 miles the other day and it did not make the Noise at all.it was not very windy out however and I'm not confident that it has just gone away and won't be back. I do believe it has to be inside the door. Thanks for keeping me posted.
Any updates to the noise
My noise ended up being the plastic duct work behind the drivers side instrument panel going to the vent on the dash.when you were at a higher speed it would rattle on top of the metal bar that is part of the dash assembly. I placed burly seal between the duct and bar. I found the problem on this forum so it has been a issue with other trucks.
Thanks for the update. Was it a rattle noise or a loud howling? I have an AT4 6.2 with 1500 miles on it and for the first time over the weekend heard this very loud howling noise that came and went when I was driving about 75 mph in strong crosswind.  So loud my wife and I went WTF.
I have a 2020 Silverado with the same noise problem when driving 70/75 mph and a high crosswind. Seems to be coming around the side mirrors. If i pull the side  mirrors in, the howling stops. Side mirrors out, howling starts. Noise is not constant, but very irritating.
1 hour ago, carortruck said:
Any update on this???
2020 crew cab same noise...sounds like someone playing the recorder badly.
Crosswind highway speeds
Haven't brought it to the dealer yet.  I'll keep you posted when I do
2020 Crew Cab—Same problem; mostly on the passenger side, but sometimes on the driver side. Nearly constant at 85 pushing headwinds or crosswinds. So loud it drowns out the stereo. Wife’s first 500 mile trip in the truck with me yesterday......she was not impressed, to say the least.
2020 Crew Cab—Same problem; mostly on the passenger side, but sometimes on the driver side. Nearly constant at 85 pushing headwinds or crosswinds. So loud it drowns out the stereo. Wife’s first 500 mile trip in the truck with me yesterday......she was not impressed, to say the least. I will try the mirrors in idea....sounds like it might be a temp fix, but being a “side mirror” driver, I need to find another fix. Thanks
One purpose of moving the mirrors from the old position in front of the glass down to the door shell was to eliminate this noise. Seems like it is airflow through the gap in the mirror pivot that is making the noise no mater where the mirror is mounted. Try putting a piece of tape over the front of the gap and see if the noise disappears.
So much for that engineering marvel that moved the blind spot created by the mirror to a different location, but did not cure the root cause of the problem.
Mine is noticeable on the drivers side, but not so bad that I have worried about a permanent solution.
Thanks, I will give it a try.
2021 Crew cab, load wind noise (sudden roaring noise then gone). In the body shop now. There is a strip of felt between the rear ends of the front fenders in the cavity behind the driver and passenger doors hinges. It is loose and twisted some all along the edges on the drivers side. All sealed on the passengers side. They say that most likely the problem.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,659 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
