My 21 Silverado 1500 sounds like a someone blowing over an empty pop bottle at 70+ with a strong crosswind.  Upper passenger side windshield is where it appears to be coming from.
 I thought maybe it was my new windshield.  This post has me thinking otherwise.  Anybody have a fix yet?
I have the same howling noise as well.  Only happens on strong windy days and I swear, I can literally feel the truck move a little likes it’s taking in wind when it happens.  Been waiting for a call back from my dealer for 3 weeks now with new door to Body seals.
I have a 2020 silverado, trailboss, and I have the same issue.  When driving into a crosswind, door or window whistles.  If it is a real windy day, it whistles so loud that I can barely hear the radio.  It is worse on the passenger side, but driver side will do it as well.  Dealership tried adjusting the passenger door twice, and it hasn't helped any.
Does anyone have any updates/fixes to this issue?
I had maybe the same issue.  I took a video of it and sent it to the service guys. It sounded like a clarinet playing a single, really bad note.  Loud enough that it was hard to talk over.  Started with a strong head wind on the highway.  The lowest speed that it would make the noise was abt 65, but more often than not closer to 80.  One of the techs said that he know someone that had seen it before.  They found it.  It was the passenger side weather-strip that cause it.  They ordered new and replaced it.  We had 30 mph north wind they day they replaced it.  The tech could not reproduce the issue after replacing the weather-stripping.
  • 1 month later...
I hadn't heard it again after that one time. Still hadn't brought it to the dealership.  Truck is 4 months old and only 2300 miles including a 1000 mile trip to buy it. I will update once I have the energy to bring it in.
  • 4 months later...
was it the weather strip around the door or window?
I just got back from a 500 mile trip out of town and experienced the same howling on the driver's side of my 2021 AT4.  Anyone know which weather stripping the dealers are changing out to alleviate this?
Thanks
  • 4 months later...
Been having this same loud whistling issue at highway speeds with my 2021 6.2 liter AT4. However I seem to notice that when I hear this whistle as soon as I crack my window the whistling stops. Any ideas?
Edited by jrollie
  • 1 month later...
Similar problem (2020 1500 RST), passenger side approximately below air vent in dash or adjacent spot on door.  Starts at about 45 mph.  Mine is more like a rattle/vibration that increases with speed.  Some crosswinds will nearly make it go away for a bit.
On 3/16/2021 at 2:28 PM, Philbert said:
Thanks for the update. Was it a rattle noise or a loud howling? I have an AT4 6.2 with 1500 miles on it and for the first time over the weekend heard this very loud howling noise that came and went when I was driving about 75 mph in strong crosswind.  So loud my wife and I went WTF.
I have a very loud howling on mine as well, but sounds like its coming near my left ear.  Was your sounds that high up on the door frame?  Mine is at 70 plus and cross winds as well. Just want to get this fixed asap. Any additional help is greatly appreciated.
Same issue here. Did you ever find a solution? It’s driving me nuts!
    • Pretty much zero rust on the truck, the frame is super clean. Non-snowy area of California for its whole life. They didn't mention JB weld specifically, just a silicone style seal.
    • Needs a manifold gauge hooked up and the pressures read.   If you don't have one, time to take it to a shop and have it diagnosed.
    • How rusty is the truck?     The transfer cases on these are an aluminum case.  If its anything like the rear diffs on the 2015-2022 Chevy Trax, those will corrode bad to the point it will push fluid through the housing via corrosion porosity or a crack from age/stress.    We have seen folks over tighten the drain and fill plugs on these transfer cases and crack them that way as well.    So I'd say its a 50/50 shot on re-sealing the case.  If all of the surfaces are good and its not badly corroded, they probably can re-seal it.  GM uses RTV to seal the case halves.   If they mention JB Weld, the issue is the case.  Be it a crack or corrosion.  JB Weld "might" hold if they clean EVERYTHING very well and drain the fluid out of the case and clean the crack and then seal it.
    • A while back, my truck (2018 GMC Sierra 1500 5.3) went in for an o2 sensor and routine service. The tech identified that my rear output seal on my transfer case was leaking, and recommended I have them replace it. At the time I didn't think anything of it, and had them do the repair. Less than a month later, I noticed that the recently repaired seal was leaking again. I called the shop that did the repair and they warrantied the repair and replaced the same seal again. A few months later, I noticed that once again the same seal leak had come back. It wasn't a great time to bring it in and I ended up just living with it for 6 months or so, noticing small (smaller than a baseball) size oil stains below the truck when it would sit for a while, as well as oil spray on the frame (to the point where it actually took the underbody coating off in that one spot). Finally got around to brining it in again, but this time I took it to a dealership service center since I am in a different part of the state for school. They identified the same output seal leaks and recommended they replace them. They also said there was no scoring on the inside of the transfer case, so it didn't need to be replaced. They chalked up the original repair failures to non oem seals and a job that wasn't done correctly. Now they called and said the seals are holding after driving/sitting for a while, but they found a very small leak in the middle, that they recommended they seal with some kind of silicone/jb weld (not sure what they are using). I haven't picked up the truck yet, but I have been reluctant about this whole repair process because I feel like they are just fixing the same thing that keeps coming back, and I am concerned there could be another root cause for the seal failing. Has anybody else experienced anything like this, or have any ideas on other things that could be the root cause?
