I bought an old 2000 Silverado 1500, and was able to successfully unlock the radio using the normal procedure found online (https://www.autoblog.com/2016/06/15/how-to-unlock-a-chevrolet-theftlock-radio/)
If your radio is locked, “LOC” is displayed on the screen.
Step 1: Press buttons 2 and 3 at the same time and hold for 8-10 seconds. Write down the three-digit code that is displayed.
Step 2: Immediately press the AM/FM button. Another three-digit code is displayed. Write it down as well.
This is your six-digit radio serial number.
Step 3: From any landline or cell phone, call the toll-free GM Radio hotline at 1(800) 537-5140.
Step 4: When it requests a code, enter “106010” on the keypad, followed by the pound (#) sign.
Step 5: You will be prompted to enter the radio serial number you have just obtained.
		At the prompt, enter the number followed by the pound sign.
Step 6: The prompt will read out your four-digit radio unlock code. Write it down precisely.
Step 7: Turn your ignition on and press the radio power button. Your radio will display “LOC.”
Step 8: Press the hour button on the radio to enter the first two numbers of your radio unlock code.
Step 9: Press the minute button until the last two numbers of the radio unlock code are displayed.
Step 10: Confirm the code. When the code matches, press the AM/FM button. “SEC” will display on the radio, indicating a successful attempt to enter your radio code.
I had to disconnect the battery to do some repairs, so of course the radio locked again. Now when I try calling the radio unlock number ((800) 537-5140) I just get disconnected, or told the call couldn't be completed. Can anyone else test that phone number, or suggest another way to unlock the radio?
Worst case scenario I'll throw an aftermarket radio in, but I'd like to keep the price down as much as possible.
Same here.   I am helping  a friend move a radio from a donor truck of the same year and shows locked.  Calling the service number is disconnected for me too.
It's nice that this site you mentioned will let you text them your challenge code and they will let you know if they can help you. $20 is steep since we don't know if the donor radio works.
It's a good deal of you have a high line radio you know works and paid very little for.
Thanks for the refence.
According to my dealership Denny Menholt Chevrolet as of 2018 the number hotline does not exist anymore service can only be done by a dealer.  You will need to bring your vehicle to your manufacture dealership of your make say Chevy or GM or whatever.  They will not charge any fees for them to give you the 4 digit master code.  They only charge you if you want them to do it for you.  For a Chevorlet 2001 Chevy Blazer the codes are 642 - 652 - 106010 (Chevrolet).  Once you have all of this go to the service center and they will give you the code.  Mine was 0150.  Since their is no zero.  just the last 3 numbers worked.  Using the minute key to 50 and hour to 1 press am/fm button to confirm.  Boom.  Stereo now works.
Edited by Pasquale D'Anna
  • 3 years later...
Obtaining a special unlock code from Chevrolet or a dealership is normally required to unlock the radio on a Chevy Silverado. Visit the official Chevrolet website or get in touch with the service division of a nearby Chevrolet dealership. Give them the serial number of the radio and the VIN (vehicle identification number) of your car. The driver's side door frame or windshield are typically where the VIN can be found. They will confirm that you are the owner and obtain the proper unlock code for your radio.
    250.3k
    Griffin Donovan
    Griffin Donovan
  • Who's Online   4 Members, 0 Anonymous, 808 Guests (See full list)
    • Hasn't come up in the 3 gm forums I follow. And only gm knows the frequency of failure of that part. LMG, you want a recall so it's replaced for free...
    • You need a better code reader/scanner.  You are missing codes.  Did the dealer give you a copy of the SAVI scan from that visit?     If the fluid hasn't been changed, change it.  Shudder will likely go away.
    • TLDR to my other post...   Hard. Pass.  Too many what ifs.     Are you set on a 3.0 Duramax?  Have you considered anything not GM just in case?  If you don't have to have a pickup, lots of other options for $27,000 out there.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.  So right out the gate it needs about $3000-3500 for that to be done before driving it another 150,000mi.  Belt is at the rear of the engine.     - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.  They will usually set a P0016 I think?  There is another $8000-10,000 if it needs a chain.  The main chain is at the back, secondary at the front so the pump belt would be done at the same time if it needed chains.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.         Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.         The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
