I bought an old 2000 Silverado 1500, and was able to successfully unlock the radio using the normal procedure found online (https://www.autoblog.com/2016/06/15/how-to-unlock-a-chevrolet-theftlock-radio/)
If your radio is locked, “LOC” is displayed on the screen.
Step 1: Press buttons 2 and 3 at the same time and hold for 8-10 seconds. Write down the three-digit code that is displayed.
Step 2: Immediately press the AM/FM button. Another three-digit code is displayed. Write it down as well.
This is your six-digit radio serial number.
Step 3: From any landline or cell phone, call the toll-free GM Radio hotline at 1(800) 537-5140.
Step 4: When it requests a code, enter “106010” on the keypad, followed by the pound (#) sign.
Step 5: You will be prompted to enter the radio serial number you have just obtained.
		At the prompt, enter the number followed by the pound sign.
Step 6: The prompt will read out your four-digit radio unlock code. Write it down precisely.
Step 7: Turn your ignition on and press the radio power button. Your radio will display “LOC.”
Step 8: Press the hour button on the radio to enter the first two numbers of your radio unlock code.
Step 9: Press the minute button until the last two numbers of the radio unlock code are displayed.
Step 10: Confirm the code. When the code matches, press the AM/FM button. “SEC” will display on the radio, indicating a successful attempt to enter your radio code.
I had to disconnect the battery to do some repairs, so of course the radio locked again. Now when I try calling the radio unlock number ((800) 537-5140) I just get disconnected, or told the call couldn't be completed. Can anyone else test that phone number, or suggest another way to unlock the radio?
Worst case scenario I'll throw an aftermarket radio in, but I'd like to keep the price down as much as possible.
  • 1 month later...
  • 2 months later...
Same here.   I am helping  a friend move a radio from a donor truck of the same year and shows locked.  Calling the service number is disconnected for me too.
It's nice that this site you mentioned will let you text them your challenge code and they will let you know if they can help you. $20 is steep since we don't know if the donor radio works.
It's a good deal of you have a high line radio you know works and paid very little for.
Thanks for the refence.
Sent from my SM-N975U using Tapatalk
  • 4 weeks later...
According to my dealership Denny Menholt Chevrolet as of 2018 the number hotline does not exist anymore service can only be done by a dealer.  You will need to bring your vehicle to your manufacture dealership of your make say Chevy or GM or whatever.  They will not charge any fees for them to give you the 4 digit master code.  They only charge you if you want them to do it for you.  For a Chevorlet 2001 Chevy Blazer the codes are 642 - 652 - 106010 (Chevrolet).  Once you have all of this go to the service center and they will give you the code.  Mine was 0150.  Since their is no zero.  just the last 3 numbers worked.  Using the minute key to 50 and hour to 1 press am/fm button to confirm.  Boom.  Stereo now works.
Edited by Pasquale D'Anna
  • 3 years later...
Obtaining a special unlock code from Chevrolet or a dealership is normally required to unlock the radio on a Chevy Silverado. Visit the official Chevrolet website or get in touch with the service division of a nearby Chevrolet dealership. Give them the serial number of the radio and the VIN (vehicle identification number) of your car. The driver's side door frame or windshield are typically where the VIN can be found. They will confirm that you are the owner and obtain the proper unlock code for your radio.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 993 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
