I just wanted to start this in hopes it helps someone out. I'm not sure how useful it is but still here you guys go.
I know there is alot of information out there about swapping power folding mirrors ,
Some say just all you need is the mirrors and boom all works
Some say you just need to swap the driver side switch and your all set
Truck into,
2015 Tahoe LT with Memory package (A45)
Parts,
Driver side switch:23488411
Passenger side switch:23488406
Mirrors: Power Folding Mirrors
The beginning,
I oped in for the larger mirrors they sell because I came from a 2011 Tahoe and it had proper mirror sizes now to a 2015 that had car mirrors lol. The larger mirrors came with memory and puddle lights and turn signal ( Turn signals you had to wire yourself). Still the larger mirrors are the way to go.
Stock VS Aftermarket
20190827_182036.thumb.jpg.c7c3fa032333afa848bb8a84870cd4d6.jpg20190827_182139.thumb.jpg.2eb9994a7c0912d18797768457f21f2d.jpg
Now that we got that out the way the mirrors are straight plug and play but you will need the correct driver mirror switch one with the power fold button ( 23488411) and you will also need the correct passenger window switch (23488406) as the power fold commands pass threw this switch as well. Once you swap that in you are all set and you should have fully working power folding mirrors. Any questions please leave a comment I hope this helped someone.
** remember this is the correct part number for a Tahoe with the memory package (A45) if you do not have this then your part numbers will differ**
Stock on driver side aftermarket on passenger side
Both side replaced
Nice install and write up! I agree, the factory mirrors on this suv platform are too small.
He’s correct folks. If you have seat memory, the 2 switches and appropriate mirrors are all that’s needed to enable the fold feature.
If you opt for mirrors with features like the puddle lamp, turn signal and auto dimming, and you have an LS or LT trim vehicle, additional wiring is needed which I can provide.
Thank you. I figured I would write this up after following bad advice from another site and getting the wrong switch originally.
Nice write up. I wonder if you can answer a question for me regarding the new mirrors you installed. Did you gain the feature of the mirrors going down when in reverse ? That's one feature I miss from my previous car. I have a 2017 Suburban LT model with just standard mirrors but would love for them to tilt down when in reverse especially now that I added wheels.
  • 1 month later...
I'm sorry for the late reply but no the option does not come up.
  • 3 months later...
does the memory function work in your new mirrors after this swap?  Not finding an answer to that.  We have A45 memory seats and of course the mirrors don't have memory.
  • 9 months later...
I have a 2020 Suburban LT and want to switch the mirrors out to power mirrors with the blinkers and lights in them, i found a used set off a 2019 for $100, will these be plug in play and will everything work
once plugged in or do i need another harness?
No, you will have to wire them for turn and puddle lamps. They will do memory and fold if you replace the passenger switch. Member cmatt makes the harnesses, and is a great wealth of knowledge with these things. I will suggest escalade mirrors as I did on mine - much larger, and I absolutely love them...
  • 2 months later...
I'm new here and was hoping that cmatt would be able to help me with the additional wiring needed to enable the use of features like the puddle lamp, turn signal and auto dimming.  I have a 2017 Tahoe Z71 LT with Memory package (A45).   Thanks
  • 1 month later...
Hello all. New member reviving an old thread. I was looking at upgrading the mirrors on my recently purchased 15 Tahoe LT with memory.  I am looking at some escalade mirrors on ebay and want to confirm what options will work. I am looking at mirrors with power folding, auto dim, puddle, turn signal, heat and blind spot.
I know blind spot will not work without an unreasonable amout of conversion but will all other functions above work with cmatt's harness assuming they are still available.
Thanks in advance.
Josh
  • 2 years later...
    KJEK
    KJEK
  • Who's Online   3 Members, 0 Anonymous, 642 Guests (See full list)
