2000 Silverado PO442
I have a 2000 Silverado 5.3L with the fault Code PO442 (Small Evap System Leak) what should I try replacing first to solve the issue? I am thinking either the fuel cap or the EVAP Canister purge solenoid and where is the EVAP canister purge solenoid located? My Scan tool has the capability of running a test on the EVAP system but what do I look for when this is done? It hasn't been starting on the first crank when sitting overnight lately but it would immediately start after retrying it seems to have quit doing that though could that be related to a bad Purge solenoid?
Thanks in Advance
One thing I've had as a problem here in upstate NY with the corrosive stuff they use on the roads is,the filler pipe to cap seal gets grungy,I have taken sandpaper to the seal area and used vasaline on it and gas cap oring,worth a try,and another is,give a look at vapor line,the line on the frame rail to purge valve,it's steel,it rusts, maybe a pinhole
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 282 Guests (See full list)
