2016 Silverado sound issue, No Treble from sound.
Hello,
I had my truck for over 3 years and I no longer have a warranty active on my truck. thought maybe you guys know what the issue is with the sound. I had great sound coming from the speakers, but recently, the treble went out and all I get is bass from the front door speakers, sometimes the treble will go out on the dash speakers and the rear door speakers are no longer working. I've been trying to search online and through the manual, but it doesn't say anything about what would cause this issue. I called the dealership and they said the radio possibly is going out or the amplifiers are going out. Can you please help me figure this out?
Thanks.
Go to radio and gade and balance it to each door and see if you hear anything. The rear doors are bass, front doors are mids, and dash are high. But it is set more like a component set and will still work a little. Then remove panels and meter speaker if blown just replace.
Where do I go on that? I don't have any options for that setting. I only have EQ to where I can set low, mid and highs. I'm using the chevy mylink radio.
UPDATE: I tried seeing if there is a hidden setting for any way to set the audio settings and getting my full sound back, but there was nothing there that helped me out. It just doesn't show how to get my sound back. I really don't want to spend a lot on my truck to get my sound back. I highly doubt my speakers have gone bad.
It should be a visual representation of the balance next to those settings. You are able to move the center circle around in that representation to control your front to back and right to left.
Sent from my SM-N975U using Tapatalk
Give me a bit and I'll get to my truck and take pictures of what I see. I'm currently at work sitting in the office waiting for paperwork and cannot leave the office unless something frees me up so I can get to my truck and have a quick smoke.
UPDATE: I got in my truck and I found that setting. I adjusted it and had it set to just the rear speakers and barely any sound, even at full volume. set it to barely in the front and the front door speakers, you only hear bass and the dash speakers keep cutting the treble in and out.
Yes that circle and move it back and right and then check rear passenger door. And so on for all doors. But what is this system? Bose amp? Because you can troubleshoot it will fuses but if it is speakers that is a different story.
1slow1500,
Missing the highs in the doors sounds like blown cones doesn't it? But I'm not sure why his dash highs would be clipping.
1slow1500,
Yeah if you knew it was a bose then you can go to wires in kick panels or even door jam and meter them. But honestly it is so easy to remove door panels I would just pull those off. Hate.to see you buy speakers and have a blown amp.
I'm not sure about dj_overspin, but I know mine is not bose and regret it ever since I got rid of my hoe that had it. It is like night and day between the two.
23 hours ago, jamisonericksen said:
I got a pic of what mine shows. removed to save space
Yeah, I just saw it on there. I didn't even pay attention to the screen till I actually looked. Got used to having dials to tell you how to balance your sound.
But back to my update from before, I adjusted it and had it set to just the rear speakers and barely any sound, even at full volume. set it to barely in the front and the front door speakers, you only hear bass and the dash speakers keep cutting the treble in and out.
I think I may be in the same boat you are. My right rear does the exact same thing. But my fronts are good. I noticed that when throwing the balance to just the rear my volume is cut in half. I'm not sure if it because of the right rear speaker having an issue or what. I'll be doing some homework on this to try and come up with something.
Alright. I have this forum post book marked on my phone and I'll have it sent to my home computer. Hopefully we can solve the issues that we can fix.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
