Going to install a motofab 2” leveling kit in the morning on my RST does anyone know the torque specs on everything you take lose? Ex. Upper ball joint, tie rod, and anything else?
Ready lift says 65lbs for the upper ball joint.  That’s all I had to take off to do mine from their instructions. If I had to do it over, I would have went ahead and took everything else loose to make it easier. It was a nightmare trying to pry on and line up the level bolts.
Edited by AD80
  • 2 years later...
Rwood1,
Did you ever get all of the torque specs you were looking for? I'm looking for the same... to do the same.
2020 1500 AT4
john
I posted them all at one point.  If you do a search you should be able to find them.
Edited by Gangly
30 seconds with the Search Engine:
For the sway bar link you have to hold the bolt stationary while you thread the nut down to the base of the bolt.  Once the threaded nut reaches the base of the bolt, you can tighten it down to its specified torque spec without having to hold the bolt as well.
Torque Specs for the Upper Control Arm Ball Joint
First:  26 ft/lbs
Second:  Additional 60-75 degrees (A little shy of a 1/4 turn of a wrench)
Strut Bolts
Upper:  43 ft/lbs
Lower:  37 ft/lbs
Sway Bar Link
74 ft/lbs
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
