Coolant leak on 5.7 vortec
Water pump was leaking on my suburban so swapped and now I’m noticing above the water pump and to the right directly under the ac compressor I’ll get some pictures in the morning but I do have a video of the leak. New to the site sorry if I posted in the wrong section. Need some ideas on what this is that’s leaking.. intake gasket maybe ?
Not sure of your year model and engine, but I have a ‘98 5700 Vortec in a C3500 and I had coolant leak from intake gaskets around 225,000 miles.  Expect corrosion on I take manifold surface as well. I was able to grind out corrosion, JB Weld, and then work it down with a file and then wet rock. Some folks wouldn’t suggest it but at 283,000 miles now and solid as a rock.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
