Door locks
KJANN06
My door locks are locking and unlocking while I drive and sit still. The only time it stops is when the truck inside heats up and or 35 minutes have pasted. I don’t get any codes or anything so I’m wondering if it’s the door lock actuator, BCM or something else? I will try to post a video
On 11/23/2019 at 8:14 PM, KJANN06 said:
My door locks are locking and unlocking while I drive and sit still also the head lights will flash and the battery plus oil gauge needle will move. The only time it stops is when the truck inside heats up and or 35 minutes have pasted. I don’t get any codes or anything so I’m wondering if it’s the door lock actuator, BCM or something else? I will try to post a video
Silveradosid I tried it and the driver side is the only side that does it now
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
