Bug shield for 2017 sierra
Billy H
Hey guys, I’m having trouble finding a bug shield for my 2017 sierra. I can find the 3M tape stick on type, but I want the old style type that takes screws to hold it on. Anyone know where I might find one? Thanks!!!
I have the weathertech one on my 2016 Silverado, it did not use the 3M tape. They don't show a picture of a Sierra but I'm sure you could contact them to see which way it is installed.
Found this one too but you have to drill holes into the underside of the hood.
https://www.amazon.com/Wade-72-98148-Platinum-Bug-Shield/dp/B00HU3DLR4/ref=sr_1_7?crid=EAE1HEIIGTCO&keywords=sierra+bug+deflector&qid=1574998432&sprefix=sierra+bug%2Caps%2C179&sr=8-7
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 511 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
