New truck, tire options?
SquireSCA
I already have a 2018 Z71 with a 2.75" front level kit, Bilsteins, 3" lift on the read, and one sizer larger than stock Ridgegrapplers...
Today I gave that truck to my wife and traded in her 4Runner for a 2019 LT TrailBoss Z71... came with 20" wheels and 265/60 tires...
Wondering what the largest tire I can shoehorn in there on this new truck without having to lift it or worry too much about rubbing.
THoughts?  will a 285/65 fit in there no issues?
Just got rid of mine at 16k miles, very slippery on wet streets. Bought KO2’s.
The sipes disappears after about 25k miles
Before
f64aa8e6e65e901f37f27ce9207de8d0.plist
On 16k miles
Worse tires I’ve ever owned!
Keep an eye in yours, your traction grabbing sipes disappears
Sent from Above
Actually, if I stick with the size on the truck now, they are 275/60r20 and I can get the Cooper ATP's for like $175 each, which I will probably get like $75 credit for each of my current tires, so $400 for a set of more aggressive tires isn't a bad deal...
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 827 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
