Trigger Accessory Control System
Done a couple of them. I find the range of the wireless controller to be no more than a few feet from the truck and there's no lights on the remote control to see if something is left on or not. The lights on the actual unit change when turned off and on but if it's mounted under the hood it's tough to see.
Sent from my Pixel 2 using Tapatalk
You can build a kit yourself for SO much cheaper. They have kits with as many as you want or you can add in a series l, I'm using my home link buttons to trigger my relays.c67fd51ad7feca77acd1220c189de228.jpg57df8d28917308b52ddebfa3955c7b3c.jpg
Sent from my SM-N975U using Tapatalk
Found another wireless Led light bar controls module Locally.
The blazer light management system. It has quite a few reviews and all average 4 stars and up. Definitely have some reading up to do. Not sure if I want to undertake attempting to wire up my own remote relay system or go with a ready made one like I’ve listed above. Lots more research to do for now
As far as building your own setup, figuring out where you want to put your components is usually the hardest part. The relays and fuse blocks are super easy to wire.
    blueskytruc
    blueskytruc
  • Who's Online   3 Members, 0 Anonymous, 618 Guests (See full list)
