Has anyone experienced the open hood warning and theft attempt warning?
My 2019 Z71 LTZ just started yesterday with open hood and theft attempt warning with the horn alarm blaring while I was staring right at it. It also gives me an open hood warning while I’m driving. I can’t use factory installed remote start. I really regret trading in my 2016 for this one, way to much electronics control this truck along with the POS auto stop. Anyway I’m done ranting.
24 minutes ago, Daniel Storer said:
I have same problem 2019 where is this sensor
Part of the hood latch.  New hood latch will fix your issue.  We do them quite a bit.
The 2019 isn't much more "electronic" than your 2016 was.  Just upgrades.  You can also disable the auto start/stop with a variety of methods involving programming OR a custom jumper harness for the switch.
  • 2 years later...
I had this issue where , opening driver side window, shifting transmision from park would activate the hood warning.  AUTO START was acting intermittent where the alarm would go off when i pressed lock on remote or, in an other intance,  it would start the engine but engine would run for 10 seconds only.  The issue was a ground strap cable from motor head on the left side (rear) to the firewall.  it was corroded/rusted and was shorting out hot.  There is a bulletin on this from GM.
What kind of truck do you have? Not a 2015 Sierra Kodiak like in your profile?
Have you considered using a POS system for this? If yes, could you recommend any particular POS system? Your suggestion might be helpful for others facing a similar situation.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,363 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
