3 codes Related?
2014 Sierra 5.3L-Remote start wasn't working, started truck and threw codes P129D, P2534, and P0700. Any ideas if these 3 are related in some way for an easy fix?
The codes aren't directly related, but they could be caused by a wiring issue. P0700 is trans related and could be a module or module wiring issue. P2534 is fuel pump module related and could be the module or module wiring. P129D is BCM related and there's a TSB for it #PIT5308C. There's a couple areas where there is can be wiring issues. Any codes stored will cause your remote start to not function properly.
I would check the related harness connectors for corrosion or moisture intrusion. Put some dielectric grease on them and reassemble. Have the codes cleared and see what happens.
Sent from my SM-N975U using Tapatalk
p0700 is just a generic "The tcm has noticed a problem" code.  You need a code reader that can get codes from the tcm, to find out what the specific problem/s are.
