Bumpers?
WyoAT4
Add and fab four have them released but would like to see a few mounted before pulling the trigger. The ADD is 200 lbs w/o a winch was wondering if folks upped springs to 700 pounds
I'm in the research stage...The Steelcraft 71-10490 Fortis Front Bumper looks interesting but I can't find a weight yet. The Steelcraft Elevation has winch capabilities
Here are my notes:
Addictive Design Honeybadger: $2240, 200lbs
Barricade HD Off-Road Front Bumper: $750 + $75.Skid plate: $80, Loop $85. Two 3-Inch LED Cube Fog Lights Included, Direct Bolt-On Installation. powder-coated finish
Fab Fours Vengeance: $2100MSRP. $1990 w guard, $1850 w/o guard. 11 gauge steel, 65lbs (manu weight). 125lbs w/o guard (webstore weight). 150lbs w guard. 2 Stage Black Powder Coat. These premium steel sensor bumpers are engineered to be light weight. Rigid 20” light bar in the center and options on each side for (2) 3X3 LEDs. The fit of this bumper is high and tight and comes with lower cutouts to provide increased airflow; while also giving you that aggressive look both on and off the road. Available in a no guard or pre-runner guard option. Complete bolt-on front bumper w/ provided brackets that tie directly to the frame. OPTIONAL: Side Light Mesh Insert.
Hammerhead Low Profile Formed Guard 600-56-084: $1789MSRP, $1484
(https://www.americantrucks.com/hammerhead-silverado1500-low-profile-formed-guard-front-bumper-600-56- 084 1.html). 11g steel, 0.187-inch thick plate steel. Machine-formed with internal reinforcements that provide extra strength without adding extra weight. 2-step black powder-coat finishing process for maximum corrosion protection. 129lbs. Mounts on factory locations without the need for modifications. Comes with all necessary mounting hardware. Welded D-Ring Mounts
Iron Cross 60-515-19 Hardline Front Bumper Without Push Bar: $1495,
Road Armor 3191F4B-NW Stealth Front Non-Winch Bumper Pre-Runner Guard Black Powder Coat: $2485, 3/16”, 270lbs
Steelcraft 71-10490 Fortis Front Bumper Non-Winch HD Lines (Elevation if you want winch): $759, 6 guage steel, 20” light bar + 3” cubes x4. Combines both e-coated and phosphate-dipped technology coatings. No-drill, bolt on mount kit.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 975 Guests (See full list)
