Thud when stopping
2003dirtymax
I have an 03 duramax and when coming to a complete stop there is a thud at about 5 mph.  The truck has a trailer brake hooked up to it that lights up when I push the brake but it isn’t in tow haul mode. Could that be the issue or is something more serious?
