1 hour ago, Chris Callanan said:
Elevation has the body colored bumpers and grill surround, black grill - but you are correct, no 6.2...   you can get the 3L though :)
You are right. It might have been the cloth seats.  He checked every combination and said the AT4 had the best combinations for him.
  • 2 years later...
upgrading to an at4 or denali, and just signed up cause of this - gregorio sounds like he knows what he's talking about on dechrome part swap - but anyone else have any numbers they want to share?  (for denali)   $6500 sounds like a lot
I checked prices on elevation trim parts and am getting lower.. but maybe you cant swap some
On my old 2017 I did an LT chrome conversion to body colored bumpers and grille and headlight bezels. I decided to remove the bumpers and get them powdercoated ($300 for both). Ordered the body colored grille though dealer for about $500. Ordered new paintable headlight bezels ($200). Got them Painted ($100). So I did the complete switch for just over a grand in parts and paint.
20190403_144404_HDR.thumb.jpg.a08bc0d8ad7bdde565e08538618d1df4.jpg20190615_180313_HDR-1.thumb.jpg.5f9b03468551efe2d8e7e5c3f07cdf0e.jpg
Edited by jaxcam02
I posted awhile back that I was following. Never saw anyone lower their at4 so i went ahead and did it. 4” drop all around. Bilstein 5100’s meant for the slt/elevation, oem axles for the slt/elevation, beltech 2” drop shackles for the rear, beltech 2” drop spindles for the front and custom made ubolts for the rear from a shop.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 497 Guests (See full list)
