  • 3 weeks later...
1 hour ago, JoseD95 said:
Bump. Looking for a set in chrome if anyone has it. Willing to trade. ?
I posted weeks ago that I would trade
  • 4 weeks later...
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
