4l60e reverse problem
Ronnie Gaines
Possibly, should be under warranty, I hope.  Don't waste anytime getting it back to who rebuilt it.  The same band is also used for manual low.  If you shift the transmission to 1 or L while driving at 10mph, you should feel engine breaking, you may need to go 15mph depending on final drive ratio.
Ok what is engine braking
If it does have engine braking is that good or bad ? Would that mean that the band is loose?
When your shifter is in Drive and you lift your foot off the gas pedal, your truck will coast to a stop, eventually.  If you watch the tach you may even see the needle drop to the idle rpm, and stay there as the speed drops and the transmission automatically downshifts. If you pay attention you will find that when push the gas pedal at approximately 10 mph, the engine rpm will jump to about 2,000 rpm before it feels like the engine has caught up to the wheels.  The transmission will be in first gear, and the low/reverse band will not be applied.
If you put the shifter into the lowest position, at about 10 - 15 mph with your foot off the gas, you will notice that it feels like the engine rpm will follow the speed of the truck. If you step on the gas and take the rpm up to 3,000 rpm and let off the gas, you will feel the engine slowing the truck down.  You can accelerate, lift your foot off the gas pedal and the engine will feel like it is connected directly to the wheels.  That is engine braking.  The difference between the two positions is that in manual low(shifter in 1st), the low/reverse band is applied. If the band is very loose, it may not be able to stop the drum from spinning, making reverse feel like it is slipping. In manual low it may feel like it is slipping on deceleration.
I don't know the line hydraulic pressures of this transmission, but, in the Chrysler torqueflyte transmissions, line pressure will be double when shifter is in reverse.
Using manual low is a handy way to help diagnose low/reverse issues.
It
What is engine braking?
Thanks
There is no "reverse band" (it's the 2-4 band) used in this transmission, just a reverse input clutch and a low-reverse clutch . Probable causes are either bad low-reverse clutch or low line pressure rise from the boost valve. Take it back to the rebuilder for repair/ warranty.
What does the 2/4 servo and band do? Do they control the reverse?
