I removed the stock tow hooks and trimmed the spot where the bracket goes thru.   Not too bad of a job, slight trimming.
Mine didn't come with tow hooks at all like it's just a blank space
Sent from my Pixel 2 XL using Tapatalk
  • 7 months later...
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
