Acadia issues?
Any issues i should ve aware of with a 17/19 acadia? Focused on a denali, been trying to find a nice used one 4 the wife But not a easy find,  with everyone leasing 3 yr olds seem like throw aways lol, cant go new because we hate the push button drive.
So far ive noticed the wheels are crap, every one has had clear coat peel, is there away to prevent this, wax?  Any other common issues?
Its either this or a xt5,
 Appreciate the thoughts
Around here you can still get new 2019's... seen some when I took my '19 in to have the tranny checked.
I have a 17 Denali.  2 issues Ive had is had to have the secondary fuel sensor replaced and had the shift to park issue, so had the assembly replaced, these were under my extended warranty.   I also have the clear coat peeling, noticed it just outside of the factory bumper to bumper warranty and my extended warranty doesn't cover wheel finish, so Ive just dealt with it.  I have about 74k miles on it in the 2.5 yrs Ive driven it.   I plan on selling it once the 2021 Yukon is available.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
