4l60E problem !!! (Slipped)
Hi guys, I am new to this forum.
I got a ls2 swapped 2009 chevy Silverado 1500 with a freshly built 4l60E transmistion with z-pack clutches and a tru-cool transmistion oil cooler (about 2 months ago), yesterday I raced my friend and when I hitted 5600 rpm the tranny slipped and went back normal when I drove it normally ,until I came back at it again and now my truck doesn't move in any gears.
(Transmission temperature readings where normal at all times)
Ahmed.
