2019 Denali 2500 Front bumper
brettski99
 am looking at a 2019 Denali 2500  but the previous owner has installed a total farmer bumper on it and I do not like the looks of it whats so ever. What have you guys installed on your Denali 2500 front bumpers from aftermarket?
Did they come already coated in the color you need?
Anyone have a white frost tricoat bumper laying around if I do but this truck?
Depending on where you are you can resell that on FB marketplace or Craigslist and do ok. People around me in Montana love those things!
I'd ask places that install those bumpers what they do with the factory take offs. They would know where to find them. You may even find them for sale from those same places I mentioned.
Hopefully they didn't butcher the frame to mount it.
Sent from the demons in my head
  • 1 month later...
Local body shops that need to source 'crash' parts may be helpful in your search.
They would certainly know of take-off sources and/or sources for factory parts.  Probably will be a 'paint to suit'.
