Katech L83 Throttle Body
5 hours ago, TJay74 said:
There is no "3rd" cat on the trucks. You have 2 primary cats and 2 secondary cats. The primary are monitored by the ECM and the O2 sensors, the secondary cats are part of the 50 state CARB requirement. They can be removed with no issues or tuning needed.
I'm going to say you haven't looked under a silverado/sierra/tahoe/yukon since about 2007 with that previous post.
There are 3 cats on these trucks, not 4. Vehicles like the camaro/corvette maybe have two primary and two secondary cats.
Here is a stock y-pipe.
And again, that is not a 3rd cat, it is a secondary cat. What you have in that pic is Bank 1 and Bank 2 primary cats and a merged secondary cat. That is the exact terminology for that cat. I have been under a new truck, I own a 2016 Sierra 6.2 and even removed the secondary cat with zero issues. Has been off for almost 2 years now.
The secondary cat was forced upon the manufactures by California and the C.A.R.B. act. up until around 2009 GM made a 49 state emission certified vehicle and a California C.A.R.B. certified vehicle for the 10-12 states that follow the CARB program. Then after around 2009 GM started to phase out the 49 state system and move over to a 50 state certified emission system.
When GM made the change it was listed as a 5hp deficit when the secondary cat was put into the system.
Well you did type out that we have 4 total cats, two primary and two secondary so...
But I still count 3 cats, so saying 3rd cat still fits the bill if you ask me. Doesn't matter that it's "secondary" to the primary ones, still a 3rd cat. ?
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
